clear lacp counters
clear lacp counters
Description
Clears the counters associated with Link Aggregations Control Protocol (LACP).
Syntax Description
This command has no parameters or variables.
Default
N/A.
Usage Guidelines
This command clears the following counters for LACP; it sets these counters back to 0 for every LACP port on the device:
  • LACP PDUs dropped on non_LACP ports.
  • Stats:
    • Rx - Accepted.
    • Rx - Dropped due to error in verifying PDU.
    • Rx - Dropped due to LACP not being up on this port.
    • Rx - Dropped due to matching own MAC.
    • Tx - Sent Successfully.
    • Tx - Transmit error.
The following command clears the LACP counters on all ports:
clear lacp counters
This command was first available in ExtremeXOS 11.3.
Platform Availability
